Vray Warnings
  • Vray Warnings
    HI there,
    I seem to be getting quite a few warnings when i render. No errors are reported but 3 or 4 warnings are.
    warning: camera matrix is not orthonormal and 'Max-compatible ShadeContext' is on
    warning: Standard material and lights may shade incorrectly
    warning: Scene bounding box is to large, possible raycast error
    Im working with a lager exterior scene all to scale with a large enviroment.
    Are these warnings just warnings or are they effecting the qulity of my renders??
    They are what they say ...just warnings..
    Natty
    http://www.rendertime.co.uk
      Check the system roll-out I quess you are using camera correction, usualy this warning does not cause any problems
      Will be fixed by above
      This one I work with all the time and it doesn't cause any trouble, I've been meaning to try the render sphere from the animation rendering tutorial to see if it makes a difference but haven't had a chance yet.
      Eric Boer
      Dev
        Thanks for that Rerender, thats alot more helpful than the first reply i got. and yip, i am using cam correction.
        thanks for that.
        Dan
          thanks for that.
          Dan
          well in defense to natty, he DID answer your question. Try rereading your original question again...
            No need for DEFENCE,
            there was no tone in my previouse reply. was simply thanking Rerender for the info
