Trouble with normal map with inverse UVs
  • Trouble with normal map with inverse UVs
    Hello, I have curious trouble with inverted UVs and normal bump, but not with GPU rendering as this Topic, but in CPU !
    Some triangles appears without matching my topology on seams !
    This affect only normal, base color and others maps working well.
    Screenshot and scene file are aviable bellow
    Thank's
    Thanks for the report. We are not exactly sure what's causing it. I've logged an issue (internal bug-tracker id: VMAX-12805) for developer investigation. The issue seems to concern rendering in 3ds Max, since Standalone yields expected results and may be used as a workaround.
      Hello,
      Any progess about this trouble ?
        Not quite yet, but the issue has already been assigned to a developer.
          Hello,
          I come back to you about the progress of this issue. It's a basic and critical feature, and we need a fix for rendering in few weeks.
          Thank you
            We cannot promise that a fix will be implemented in that timeframe, however, you may still use the Standalone workaround.
              I Hope that you can do it, cause I can't switch the render farm in standalone...
                Hello,
                I come back to know what about prgression. It's a critical feature and I need a Fix for lot of objects (All my trees for exemple)
                Thank you
                  No movement yet, I'm afraid, but I've notified the devs about it again.
                    Hello, I come back about news ?!?
                      The issue seems to be fixed in our internal builds.
