Render ignoring light visibilty
  • Render ignoring light visibilty
    I have had this happen a few times, might be something to do with lightmix screwing something up or a max thing, not sure. But you can see from the image that the render is ignoring the light visibilty toggle in the scene explorer. Lights are set to invisible, but still render.
    Scene attached
    Vray6 GPU hotfix 3
    recommended drivers
    3dsmax 2023.1​
    e: info@adriandenne.com
    w: www.adriandenne.com
    There is a "render hidden lights" toggle in the "Settings\Global Switches" tab of the Render Settings.
    That's "on" in your file. Turning it off will not render the hidden lights.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      nice one, thanks for that!! I wouldnt have expected it to be set to overide the scene explorer by default though.
        It hasn't ever changed: for situations where many lights are present, hiding them via scene explorer or layer properties (the modified property is always ".isHidden") is (much!) beneficial to viewport performance, but doesn't necessarily mean the light ought to be off.
        Meshes ofc work differently, which may be confusing, hence the toggle.
        Lele
        Disclaimer:
