Forest Pro
  • Forest Pro
    I am having a severe issue with Forest Pro and V-Ray. When I have any Forest Pro item, it takes at least five minutes to cancel the render. With the Forest Pro off, the scene cancels as usual. Everything is updated (V-Ray, Forest, Windows, and MAX).
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Can't say I have seen that issue.
    I have seen one where I duplicated a Forest Pro and then changed it, and then it crashes on render. If I duplicate that copy and hide the second forest (the first duplicate of the original) then it works. If I unhide that first copy it crashes on render. If I delete that first copy so I only have the two visible Forest Pros it crashes. IF I leave the first copy hidden and enable the original and the second copy (so two active nodes) it works... Weird, I know. I have seen this with the current 8.06, and with older versions, maybe 7 or 6...
    Generally Forest Pro is very stable and amazing, but occasionally you run into some weirdness. I would check on the iToo forum, or contact support.
      I found some Autodesk Materials in the scene, and when I converted those, I think things improved. They were not on the Forest items, so I am not sure. I posted it on their forum, and I'll check it there. I also ran their optimization tool, which might have helped.
      Thank you for the reply.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Good luck.
