Creating a Glare Effects result render element works fine as a local render, but Deadline will not create a Glare render element image.
1. Create a scene using Lens Effects: Save Glare Channel ON, Create effectsResult Channel ON
2. Set up for Separate render channels to save this image.
3. Render locally and the result is, as expected: You get an image file of the Glare effect good for compositing.
4. Now send this to Deadline and the result is: Glare will composite onto your rendered image as expected but will not produce that extra Glare Only image file that the local render was able to do.
Am I missing something that would let this happen?
Can we instead have a Render Element that is the effectsResult Channel that Deadline will respect?
What am I doing wrong?
Thanks
Andy
BTW, I really like the Glare results and would use them more if they worked with Deadline. Also, I don't know if anyone is working on Deadline anymore.
Thanks
Andy
