Viewport and Material editor issue
  • Viewport and Material editor issue
    Hey everyone,
    This is my first post in vray forum.
    I have been using vray for many years and never have experienced this problem.
    My viewport and material editor are behaving wierd, I am not getting High quality viewport display and my material editor preview looks wierd......
    Can anyone guide me whats wrong.
    I have re-installed Vray 6 hotfix 3 - still problem exist....I even tried re-installing nightly vray 6 latest fix, still same problem.....I even upgraded my graphic drivers to the latest version, still the problem is same.....
    The only thing left for me is to uninstall 3dsmax and all plugins and re-install everything.....but before doing that, I wanted to know, if there is any fix.....Coz uninstalling and re-installing 3dsmax is a long procedure...
    Thank you in advance
    Hi, thanks for posting. What happens if you switch to another render engine for example Arnold? Do you have the same issues?
    Vladimir Krastev | chaos.com
      Hi!
      Thank you for replying.
      This is what it look with Vray and Arnold
      1) Vray
      ​2) Arnold
ID:	1171099​The Slate editor preview still looks wierd with Arnold also......but the viewport i guess looks ok......
        [SOLVED] it was 3dsmax issue.......I nuked ENU folder and my problem was solved......
        Thank you for your time
          Great, thanks for your confirmation.
            hey there, yeah the problem was solved, but the real culprit was "system unit setup" for some reason it was set to kilometers, and due to that slate editor preview was bad......I think 3dsmax has this depth issue with system scale.....I checked and re-checked and that was the issue....
