Vray clipper creating artifacts on excluded object
  • Vray clipper creating artifacts on excluded object
    I have included one mesh that is a simplified copy of the detailed mesh. The simplified mesh was converted to a clipper. Both objects are linked and animated to pass through a plane. The plane is the only item included in the Vrayclipper list.
    I seem to be getting artifacts of the clipper mesh on the more detailed mesh...it's a glass object. Is there any way to resolve this?
    With clipper mesh only including the plane below. (wireframe type artifacts appearing).
    Without clipper. No artifacts - it also renders a LOT quicker.
    Regards
    Steve
    My Portfolio
    As a solution I ended up using distance tex which worked but still wouldn't mind knowing if there is a solution to this?
    Regards
    Steve
    My Portfolio
      Best you send us the scene so we can take a look.
