Hi there,
after installing the latest version of vray6 ( build 31828 ) i have a very annoying problem using the blend mat.
Just built a material with 3 coat materials in the slate editor, nothing fancy, only some pbr textures with a falloff map in the first blend and a second with a procederal noise. But the second can't be connected, only a red dot shows up. I used the compact mat editor, the same - i cannot insert any map in the mask slot - in any mask slot btw
After deleting the blend and using a new one it works as expected...
But after a few new connections while using the interactive rendering, it started being weird. Nodes which were ok before can't be connected suddenly(??)
Superstrange... Can you please help?
Thank you
Sascha
Thank you
Sascha
