Material IDs in almbic file
  • Material IDs in almbic file
    Houdini geo (mixed geo and packed geo) with prim groups _00, _01, etc. -> exported to alembic -> imported to max as vray proxy
    Packed geos have wrong material id's in max.
    When I import alembic through regular max importer everything is ok.
    Houodini:
    Click image for larger version  Name:	image.png Views:	0 Size:	368.3 KB ID:	1172017
    Max:
    Click image for larger version  Name:	image.png Views:	0 Size:	86.5 KB ID:	1172016
    sample alembic file:
    szafki_A-02.zip
    Try one of the latest stable builds.
    This works fine on my side:
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      The handles and the rear boxes should have different material IDs. In your screenshot they have the same ID. Its wrong.
        EDIT: nvm me. max imports it correctly.
        Lele
        Disclaimer:
          Left, First max import.
          Middle, V-Ray proxy import
          Right, Second max import.
          If i inspect the mesh with the max importer, i see the exact same structure as i see when i do so with the proxy, and *four* IDs, from 0 to 3.
          Something isn't quite right in how that cache works with Max (leftmost has 5 ids, and is taking the fifth material from nowhere at all.), and as a corollary with us.
ID:	1172068Click image for larger version
          Lele
          Disclaimer:
