VrayMultiSubTex + Motion Blur = Huge slowdown
  • VrayMultiSubTex + Motion Blur = Huge slowdown
    Rendered in 3dsmax 2020, Vray 6.00.21,
    Windows 10,
    AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz, 128GB
    Found another issue with VrayMultiSubTex , if you have a VrayMultiSubTex in the translucency slot and Motion Blur enabled, the scene becomes impossible to render.
    Look at the image attached with just a couple of trees. With just a bitmap in the translucency slot it takes 43.9 seconds to render but with a VrayMultiSubTex takes it takes 29 minutes. this was rendered at 480x270
    If you disable motion blur it renders in 38seconds
    Guillermo Leal LLaguno
    www.evvisual.com
    www.steelbluellc.com
    We'd need to see the scene, if at all possible.
    Please submit a ticket (f.e. via the V-Ray menu in max) and point to this thread.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Lele,
      I just uploaded a sample file.
      Found something else before summiting the file. If you collapse the animated proxy to an editable mesh, it renders fast, even with the VrayMultiSubTex in the translucency slot
      www.evvisual.com
        Thank you!
        Would you have the ticket number?
        Lele
        Disclaimer:
          yes
          #85441
          www.evvisual.com
            Thanks a lot!
            The issue is confirmed, our internal ticket unmber is VMAX-13023.
            Lele
            Disclaimer:
              Thanks Lele
              www.evvisual.com
                This is reported as fixed in the latest stable for 6.1.
                Lele
                Disclaimer:
