Motion Blur and object offset
  • Motion Blur and object offset
    Hi
    I'm on Vray 5 yet. I have an issue with a character who does an extrem bounce, I'm not able to render him in this extrem position, unless I turn Motionblur off. He is slightly behind, the point of Impact.
    here you can see a side by side, the left side of the sliderline is rendered without Mblur, on the right side is the same frame with Mblur:
    I rendered with this settings:
    any ideas? Or Am I not understanding the system?
    cheers
    Michael
    Add on:
    Is it possible that this can be due to a scaled rig? It's a custom rig (not done by me). And to make it fit into the scene I scaled the master helper of the rig to 60% of its size.
    I just linked a point helper to the COM-controller (center of mass) and collapsed its animation (via MB collapse, which unlinks the object and puts a key on each frame). While both object stay together over the whole animation, They have different animation curves! which i find interesting. I can only explain that with the COM living in a space, 40% smaller than the one of the pointhelper.
    the circle is the COM, the cube ist the point helper:
    any Ideas?
    many thanks in advance
    Michael
      You may need more motion blur geo samples, try 4-6 with extreme motion this may be required.
      Dmitry Vinnik
      Silhouette Images Inc.
      ShowReel:
        Try a VRayCamera, and set the motion blur to 180deg with an offset of -90 deg. Also make sure your camera is not scaled. I don't think this affects motion blur, though, but it does mess up depth of field.
