Vray_vfb_affect_swatches
This topic has been answered.
  • Vray_vfb_affect_swatches
    VRay 6 hotfix 3, max 2023
    this env variable does not work in my case. there is no issues with other vars.
    I tried with VRAY_VFB_AFFECT_SWATCHES​ = 1 (ocio).
    Am I correct expecting material swatches in mat editors to be affected by ocio config with this env var?
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
  • Answer selected by hermit.crab at 08-03-2023, 04:29 AM.
    After a lot of testing, it turned out the variable was renamed to VRAY_VFB_COLOR_CORRECT_ALL. Note that for it to work, a render must be finished prior. So, basically: Switch to OCIO -> Render -> Manually Update Shader in Mat Editor. We'll update the docs to reflect the change.
        got it. working as expected now.
        thank you for this.
        Marcin Piotrowski
        youtube
        CGI OCIO config 04
          Additionally, I've logged an issue (internal bug-tracker id: VMAX-13091) for the swatches to update automatically.
