Can't pick the right Cryptomatte item in Panorama View
  • Can't pick the right Cryptomatte item in Panorama View
    Can't pick the right Cryptomatte item in Panorama View. For example, you pick the walls, but the floor is added to the list.
    Every time you want to pick a mask, you have to exit Panorama View mode.
    HI, thanks for posting. It seems to work on my end.
    Vladimir Krastev | chaos.com
      Have you entered the Panorama View mode?
      Here is another scene, same issue. I picked the chair but the wall is added.
        Here is what I have done:
        Could you test in a new simple scene and let us know how it goes?
          Hi, we reviewed this issue again and it turns out you are correct. I have used 90 degrees Vertical FOV in my initial test. If we use 180 degrees Vertical FOV the issue is reproducing as you describe it.
          The issue is logged under VMAX-13117 in our bug tracking system.
