vray mesh export dialog missing
  • vray mesh export dialog missing
    Hi
    I am not sure when it gone but it would be great to point me where I should look for in Customize User Interface (as I was not able to find it) to make a shortcut. I have fairly fresh 3ds max (2019)install and have tried to reinstall and install few different vray versions. Currently on latest V6. Thank you for your help.
    Best Regards
    Tomek
    Portfolio: http://dtown.pl/
    Hi, thanks for posting. These commands were moved from quad menus to the main toolbar. Please check the image below.
    Vladimir Krastev | chaos.com
      Ok, missed that... Thank you!
      Best Regards
      Tomek
        Click image for larger version  Name:	3dsmax_2023-03-23_11-03-13.jpg Views:	41 Size:	87.9 KB ID:	1176305
        But if I need to return as it was.
        I call "Vray menu registration" and nothing works.
        Only through "Custumize user interface" it turns out to set everything up.
        Why is that?​
        Thanks
          Why is that?​
          Thanks
          Because we changed it. And yes, manually adding them through the Customize User Interface menu is possible.
            Hurry up =)
            Isn't it more logical to leave it all optional?
