Vray still can't do proper opacity controlled via map...
    Not seeing the issue here... Just slow render times.
    See the attached scene. Perhaps you are doing something differently. This is using a non-dithered 16bit per channel PNG file as the gradient (included).
      Did that test scene render with banding for you?
      Note I set the color transformation to none.
