Matte compositing reflection elements – known limitations/bugs?
This topic has been answered.
  • Matte compositing reflection elements – known limitations/bugs?
    Hi all.
    This issue is related to getting reflections on matte surfaces in render elements
    Simple example scene: background- gray corner, hero- red ball.
    All materials have full contribution to alpha, then reflections are rendered to Light elements, and VrayReflection.
    The non-matte set up:
    Now If background material is set to be a Matte surface (either via VrayMtlWrapper, or Vray object settings), the full RGB renders correctly, while reflections don’t show up in any of the render elements, hindering compositing options. Like so:
    This a big problem for compositing, that I’m currently trying to work around. Especially was expecting to have light control in composite.
    Matte settings just in case:
    Any insight into whether this is expected, or bugs, or I have something wrong in my setup would be much appreciated. Thanks!
  • Answer selected by hermit.crab at 12-04-2023, 01:57 AM.
    Turns out it's a known issue (internal bug-tracker: VMAX-6479). LPEs display the issue as well, unfortunately. Logged it in as well (internal bug-tracker id: VMAX-13218 ). What you can do is use the current Full Light Select (without matte reflections/gi) and extract it from the RGB. This will get you the missing information.
      Hm, I'm uncertain if matte reflections are considered. I'll do some testing and write back.
          Thanks for the update. And thanks for the suggestion, yep that totally works, much appreciated!
