V-Ray Toolbar in Chinese after update
  • V-Ray Toolbar in Chinese after update
    Good evening to all,
    I just updated V-Ray to version 6106 and to my surprise I found the toolbar that has tooltips in Chinese.
    The remaining part of the settings is obviously in English like Max's interface.
    Does anyone have solutions to suggest.
    Thanks in advance.
    >B.​
    Yup! Quality control issues ?
Name:	Screenshot 2023-04-11 085959.png
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      I can't reproduce this here right away; can you check what is the language selection in the Settings tab of the Render Setup dialog? Also which 3ds Max version? Does it go away if you set the language to English and restart 3ds Max?
      It's a bit weird that in Bobby's case it is the Vantage toolbar and not the V-Ray one. Are the tooltips on the V-Ray toolbar also wrong?
        Hi Vlado, I have already done the checks you suggest and the situation has not changed.
        Frankly, the only attempt left for me is to uninstall everything and try a clean install without updating.
        I'll update you on that.​
        >B.
        (Edit)
        platform > Max 2023 on Win 11 Pro
          Nothing to do, even after installing from scratch the situation is that of the attached image​.
          >B.
            Confirmed Max 24 and the Vray update has all tooltips in Chinese apart from the scatter section. Swapping to English makes no difference.
            Just fyi the tooltip for 'send animated scene to Vantage' is missing.
              Ok, thanks a lot for the information - looking into it. It looks like we can reproduce this on some machines.
                Looks like we have a fix for this coming; many thanks for the reports and apologies for the inconvenience!
                  一点问题都没有。​
                    Fast and Serious.. as usual​!
                    >B.
                      Hehe, yes, the V-Ray for 3ds Max team responded very quickly. There are new builds on the site which should fix this issue (the builds are from today, April 12th and the version shown in the About dialog should be 6.10.06 build 00001): https://download.chaos.com/?platform=49&product=47
                        Just updated...and everything is back to normal.
                        Thanks to all the team​!
                        >B.
                          Great, thanks for confirming!
