PackageContents.xml doesn't exist
  • PackageContents.xml doesn't exist
    Updated from vray 6.1 to vray 6.10 this weekend.
    When 3ds max starts up i get this msg : "./plugins/vrayalmtl2023.dlt" specified in "C:\Users\**\AppData\Roaming\Autodesk\ApplicationP lugins\VRay3dsMax2023\PackageContents.xml" doesn't exist.
    Is this something that can be ignored or ...?
    Max2023 / Windows 10pro.
    Cheers.
    Found it strange i was the only one reporting this so there had to be another reason i was getting this popup.
    Seems windows defender thought the file "vrayalmtl2023.dlt" is a trojan.
    I only have defender running on my workstation, this never happened before. Strange.
    I guess its save to whitelist that file?
      I don't have an answer for you, but I have the same message this week. When starting 3dsmax 2023 (not other versions) and Windows Defender as well​
        If you download your V-Ray setup from the official download section of our site I can assure you that is a false positive detection.
        Kostadin Botev
        Contact Support
        Chaos
          I got this error yesterday for the first time. But mine says something about metaball plugin.
          "./plugins/vraymetaball2023.dlo" specified in "C:\ProgramData\Autodesk\ApplicationPlugins\VR ay3d sMax2023\PackageContents.xml" doesn't exist.
          Max2023 Win11, Vray 6.2
            How did you solve it?
              I am having the same issue today in both max 2023 (v-ray 6.2) and 2025 (v-ray 7) versions. tried re installing a couple of times.
              chaosscattermax2023.dlt and chaosscattermax2025.dlt doesn't exist.
                Did you ever solve this? I'm trying to install VrayFur Styler and I have to add a line of code to the 'PackageContents.xml.' The documentation only says to add the line to the list, but gives no tips on how to do it properly.
                When I put it in most places I get the error above. When I put the code after everything else, no error, but no modifier either. I just don't know how to properly insert the code. Any tips?
                V-Ray 6.20.06, 3ds Max (3D Studio thru Max 2025), GIGABYTE X570 AORUS Master Motherboard, Ryzen 9 3950x CPU, Noctua NH-D15S CPU Cooler, 128 GB G.SKILL Trident Z Neo DDR4 Ram, NVidia RTX 4090, Space Pilot Pro, Windows 11, Tri-Monitor, Cintiq 13HD
                Autodesk Expert Elite Member
                  I have answered you here.
