Decals can't be excluded from lighting
  • Decals can't be excluded from lighting
    As the title suggests this doesn't work, which is a bit of a bother.
    Specifically the example is labels on bottles, where the label needs to be often
    separately lit.
    It would be great if this worked
    Hello,
    I made a note about your request for our developers to look into. However, what would you expect as a final result ? For example, if decals don't have masks included, should they be entirely excluded by their gizmos from lighting or in case they do have masks, what result should be expected and etc.
    Philip
    Philip Shounev
    QA department
    Chaos
    philip.shounev@chaos.com
      Thanks. Normally I'd expect them to be excluded either with/without a mask.
