HDRI not showing up in background
  • HDRI not showing up in background
    Never had an issue, but slowly they started to work half the time and now the background is just white. The exposure seems correct, but I just can't see the background at all on any of my HDRIs. I've re-imported them, started new files and uninstalled re-installed with no luck so far.
    I'm using Vray 6 Update 1.1 on Max 2020
    Any help would be appreciated! Thanks
    Click image for larger version  Name:	asdf.png Views:	0 Size:	143.4 KB ID:	1179727
    Seems to only be affecting new files as old files HDRIs are working. So I opened an old file, deleted everything except the HDRIs and merged my new file into it which seemed to make it work.
    Instagram:
    https://www.instagram.com/deebee_cg/
    This has been another issue for me though. Adjusting a vray color completely messes up the HDRI when viewing the the VFB....?
ID:	1179731 Click image for larger version
    Instagram:
      Make sure you're in Perspective view (Orthographic does not produce correct background results). If that's not it, do attach the scene so we can take a look.
