Something odd with VRayEnmeshMod
  • Something odd with VRayEnmeshMod
    Went to move the position of some chairs I modeled and the enmesh vanishes when I render. If I undo the move they render just fine again. At first I thought it might be something weird with grouping so I ungrouped everything, then selected all and moved. Enmesh models vanish. If I select the enmesh models by themselves and move them they render fine. Not sure what's going on.
    Hello and thanks for pointing this out!
    Can you just check please, when you move the chair if you press the "Fit in object space" button in the VRayEnmeshMod will render of the pattern be fine? I believe the gizmo of the modifier may be misplaced after the object moves.​
      Hi yes this worked! Just another addition, it also works with instanced versions.
      Thank you for your suggestion.
        Glad this workaround works for now - VRayEnmeshMod's gizmo should move with the source object, so it is logged in our internal bug tracking system as VMAX-13060 for further development.​
