bright spots with glossy refraction (the images)
  • bright spots with glossy refraction (the images)
    no glossy:
    with glossy:
    Which V-Ray version are you using? Also what are the lights in the scene?
    I suspect the blotches are a result from GI caustics though.
      Thanks for the reply,
      I am using 1.47.03
      I will dive into this in more detail a little later, just wanted to know if more people experienced these kind of effects.
      The objects are imported cad files, imported with Powertranslators.
      The objects are lit by vray lights.
      I will do a test later when I have a bit more time if it has to do with the imported geometry.
        Vlado, it seems to relate to GI caustics, like you said. Does this mean that I would need to use very high settings to get rid of this effect?
          I would just turn GI caustics off.
          You probabaly dont need them at all.
            then GI light doesnt go through transparent objects. have you tried with max models rather than imported ones?
              ooo yeah of course.....hmmm that was stupid of me.
              Half asleep at work... my bad
                Yes I did, I got the same 'error'.
                In this case I think it is best to not using glossy refraction, or hide them when calculating GI.
                  Do you have both refractive and reflective GI caustics turned on?
                  What happens when you turn off affect shadows? This option actually fakes refractive caustics, so when enabling it, refractive GI caustics are disabled automatically for that material (or so I tought).
                    its just strange seeing as how ive used glossy refractions before and never had this
                      Flipside, I am using only refractive GI caustics.
                      When I turn off affect shadows, the effect is still there, only less aparent.
                      Da_Elf, indeed it is strange, and I cannot remember having seen this before. I will try to post a scene tomorrow with minimal objects, if someone wants to take a look.
                        what scale are all your objects?
                        Chris Jackson
                        Shiftmedia
                        www.shiftmedia.sydney
                          Have you tried to just quickly recreate the bottles out of splines?
                          Also it looks like they dont have inside faces...maybe true putting a shell mod on them and see if that helps.
                            The scale is cm. The bottle is about 34 cm heigh.
                            I've rebuild the object from a spline and a lathe modifier.
                            I attach a sample scene right here (max7):
                            http://members.home.nl/dezwart/test/GI-trouble.rar
                              Gijs,
                              Im having a look at your file now to see if i can see anything odd
                              Chris Jackson
                              Shiftmedia
