Here is a scene where I have an sss plane and a teapot behind this plane. The vray light is casting a shadow and gi is on. When affect shadow is off in sss vray mat it looks like image 1, when affect shadow is on the teapot seems to cast a different intensity shadow thru the sss plane, however it seems since there is only one light source that the shadow should be the same as the one cast buy the sss plane since it pases thru it.
No affect shadow
Affect shadow
Second bug is again with affect shadow, where object is thin it casts a very different shadow then what it appears to be. Here is 2 comparisons again:
affect shadow off
affect shadow on
as you can see the cup seems to be not transparent so much to cast such a transparent shadow. All tho it and a sphere have same shader the effect is totally different.
No affect shadow
Affect shadow
affect shadow off
affect shadow on
