V-Ray GPU: Can't set properties via Maxscript
  • V-Ray GPU: Can't set properties via Maxscript
    I need to control some render parameters programmatically. But when I try to do this:
    Code:
    rt = VRayRT()
    rt.renderMask_type = 0
    ... it throws an exception:
    Code:
    -- Runtime error: Attempt to set read-only property: renderMask_type
    I really need to get this working. What can I do to make this work? Why is it a read-only property? Is there some other way to set this?
    This is with V_Ray_GPU_6_Update_1_2:V_Ray_GPU_6_Update_1_2 in 3ds Max 2024.
    Thanks!
    Hello simon_lundberg
    You can use this maxScript command to modify the V-Ray GPU render mask:
    Code:
    rt.V_Ray_settings.imageSampler_renderMask_type​
    The .renderMask_type property you tried to utilize provides just read-only access to the .V_Ray_settings.imageSampler_renderMask_type​ property by design.
    Margarita
    Margarita Stoeva | chaos.com
    Chaos QA (V-Ray for 3ds Max)
      Thank you, Margarita! It would have been nice if that was documented somewhere, or had a more clear error thrown.
        Here is one documentation page that might be of help.​ Read carefully till the end of this page for V-Ray GPU.
        You can type showproperties vr.V_Ray_settings in the 3ds Max listener (F11) and this will give you a list of all available properties for GPU and after that you can use the search to find what you need.
        Vladimir Krastev | chaos.com
