Hi. I've just deleted an image from VFB history by mistake and can't find it in the recycle bin. I've recently started using the "Use project path" option in the VFB settings so the images are saved in the project folder. Could this have caused this? I haven't had this issue before.
I deleted an image from VFB history by mistake and can't find it in the recycle bin
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
3ds Max 2023.2.2 + Vray 6 Update 2.1
AMD Ryzen 7950X 16-core
64GB DDR5
GeForce RTX 3090 24GB + GPU Driver 551.86Tags: None
I'm thinking if the project path isn't a local one, for instance a NAS or something, what happens to the deleted file? Is it also going to the recycle bin?
Yes, the project is not on a local drive. It's on a mapped network drive which is an HDD in another PC on the local network. There's no issues if I disable the option "Use project path".Aleksandar Mitov
64GB DDR5
Originally posted by Alex_M View PostYes, the project is not on a local drive. It's on a mapped network drive which is an HDD in another PC on the local network. There's no issues if I disable the option "Use project path".
I can't find it in the recycle bin there either. It's as if they get permanently deleted.Aleksandar Mitov
64GB DDR5
