User scaler in Vray switch material
  • User scaler in Vray switch material
    User scaler in Vray switch material works fine with geometry but it is not working with a Vray Decal
    The 3 manhole covers at the back are geo and they switch from material to material correctly
    The 2 manhole covers in the front should not be identical. They are made with Vray Decals and are not swapping correctly
    As the vray switch material isnt working I rebuilt the shader using Multisub tex and object ids. This is more complex but works sort of.
    The bump on my ground is being affected by the vray decal incorrectly. You can see a dark square that is from the decal. The opacity map is cutting the diffuse map correctly but some other data is carried through and is creating a dark square on the bump map of the asphalt material
      The UserScalar/UserColor issue has already been resolved. The fix is already in the official builds.
      As for the second issue - send a simple scene so we can troubleshoot.
        Downloaded the new build and userScaler is working. Thanks.
        The bump issue should be easy to recreate. Really not doing anything complex. See attached zip
          Thank you. The issue is reproducible. I've logged it (internal bug-tracker id: VMAX-13413) for dev investigation.
            Any idea how long it will take to fix? Vray decal is kind of useless at the moment
              We can't provide an exact estimate, sorry to say.
