Black Render
  • Black Render
    What would cause this? Working fine all day, but BAM! I deleted and replaced the camera, sun system, and reset V-Ray to troubleshoot. Nothing in the scene changed from when it worked and when it broke. Light Cache renders just fine.
    Click image for larger version  Name:	Screenshot 2023-07-27 181129.png Views:	0 Size:	778.2 KB ID:	1187252
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Now my VFB will not show up. I reinstalled V-Ray, but it still isn't working. I checked my license and it shows I have one, but nothing in use.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      The only thing that changed on my PC is a Autodesk Identity Manager install, from the Desktop Connector app. which installed today.
Name:	Screenshot 2023-07-27 194349.png
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        It seems I got a virus from Autodesk. I had to do a deep scan, uninstall what was installed by AD today, remove V-Ray, and reinstall. Now everything is working.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I spoke too soon.... I am still rendering black.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I deleted my V-Ray Cameras and used a physical one. Now I am back in business. The virus might be a coincidence. I amnot sure why I lost my VFB, so maybe it was't a coincidence.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Has be a driver,
              try Sini software and run the forensic on it.
              To me its a driver. have you tried other scenes.
              Do you want to send it to me, Ill have a look at it,
                I do use Sini and use it daily; great software. It was the V-Ray camera, for sure! Once I deleted the V-Ray camera and used a physical camera, everything went back to normal.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Hi, does it happen if you make a new V-Ray camera with the default settings? It's not pure black, so it might be something related to exposure.
                    I have had the same issue a few times, and I generally restart and flush the ram so to speak.
                    rest cameras and rest the render setting. I alway think, I have pressed some short cut that is not obvious to me , in max.
                      I dont know, but nothing was changed on the camera. Using a physical camera solved the issue. The V-Ray camera has become unstable over th past couple of releases/updates so it should have been one of the first things I checked.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Another project, 100% unrelated to the one above, and again the V-Ray camera crashes. Working fine all day and then BAM!
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          It seems to be a RAM thing. I can drop the resolution in the VFB and it renders (75%). This isn't a very bug scene, but something is draining the RAM. I have both Railclone and Forest Pack Pro in the scene.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            Maybe not a RAM thing. I rebuilt the texture and now it is rendering fine. I rebuilt the texture the same way as I did the original one, but now it is working. I am having strange issues with scale. When I collapse a Railclone object to a mesh, the UVW is off. I even reset the XForm, but it doesn't matter. Everything has a 2' UVW, but the Railclone needs a 40' to match.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
