Vray only rendering selected light?
  • Vray only rendering selected light?
    This might be some obscure setting or very annoying bug, for some reason only the selected light is being rendered in IPR. In the video everything except the vraysun + environment sky is turned on. Freezing the layer also messing it up with the sky going really dark but the sun visible. Also, If we select a camera all the lights get turned off (but the background sky is still visible but not casting light). Yet if nothing is selected it will render correctly. The render selected option isn't being used, it's set to view. Same issue on multiple pc's.
    https://we.tl/t-h02yuybo2s
    MAX2023, latest versions of vray.
    IPR Debug shading is active and set to "Isolate Selected". Disable it.
      ahh, thanks!
