Vray scene export issues
  • Vray scene export issues
    Hello, Im using 3ds max 2023, Vray 6.1 1 - on win 11.
    When i export the vray scene, using the "archive files option" - the resource folder does not generate. Is somone aare of a resolution.
    I m not doing cloud rendersing, and all basic chcecks listed in documentation have been made. The analyse option before export also does not throw any error.
    Hi, thanks for posting. Could you try a different location? Does it work if you export only the vrscene? Could you please record a short video of the issue?
    Vladimir Krastev | chaos.com
      Thanks Vladimir, I will share a short video.
      though i have done testing of changing location and it has not helped. & It is happening in both case, if I use the archive option or not.
        Hello Vladimir,
        here is the video showing the process.
        https://matw-my.sharepoint.com/:v:/g...c3k2A?e=vxuWXm
          I still don't see the issue here. In the Test2 folder we have the Bottle.vrscene, Bottle_Final.max and Artwork-01.tif. This is all we need as far as I could see? If you want the files packed in archive then enable the "Archive as ZIP" checker.
