final output problem?
  • final output problem?
    May I know how to solve these artifacts on my final render? never facing this before...
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    where are artifacts being encountered? Not very obvious what you actually mean. The black lines? Its a bit to abstract - at least to me.
      Or the posterization (banding) in the ceiling? In that case you need to add noise. You can try to save in a higher bit depth format (32bit float like EXR, or 16bit PNG), but you pretty much need to add noise to get rid of it.
        The posterization in the ceiling
        Jackie Teh
          add noise? yes, this images I save in tiff 16 bits
          Jackie Teh
            Noise/grain is pretty much the only solution to banding. The posterization can occur at many different levels-- in the file format (unlikely at 16bit) in the display, in the display LUT, etc. Noise/dithering is really the only way to hide it. If you are using a denoiser, perhaps don't... or add noise back in.
