If you check deep output but render with progressive the finished renders simply aren't saved. I would expect an output to be written even if it's a non-deep standard image.
It would be a good sanity check to also pop up an error like there is for "Are you sure you want to overwrite existing raw images?" for "You've checked Deep but your progressive mode will render deep. Continue? Yes/No".
