ChaosScatter Select List Opens Wrong Dialog
  • ChaosScatter Select List Opens Wrong Dialog
    When you click the list [...] in Chaos Scatter in order to select multiple Distribute-On Target Objects or Instanced Model Objects you get the Exclude/Include Dialog. Shouldn't you get the Select From Scene List Dialog?
    The current dialog doesn't even let you select splines. So it's not of much use.
    Click image for larger version  Name:	image.png Views:	24 Size:	10.9 KB ID:	1193002
    What you get:
    Click image for larger version  Name:	image.png Views:	19 Size:	39.4 KB ID:	1193003
    What I would expect:
    Click image for larger version  Name:	image.png Views:	19 Size:	74.4 KB ID:	1193004
    It has always been like this. But, indeed, it does seem to need some improvements. I'll mention this to the ChaosScatter team.
      Thanks. The current dialog won't let you pick splines or lights (which can now be scatter objects (thanks for that). So the second dialog would be much preferred. It also allows filtering and searching, etc.
