Vray Stops rendering After couple of Frames Or some time Few More Frames in an animation
  • Vray Stops rendering After couple of Frames Or some time Few More Frames in an animation
    Can anyone help with the issue,
    Am working on a project and VRay Stops rendering after several frames and its not consistent, say sometimes it stops after 2 frames and sometimes after 20.
    3ds max 2021
    vray 6 update 1.2
    Win 11 Pro
    TRX 40 AORUS PRO
    BIOS - F6
    AMD 3970X
    128gb RAM
    RTX 3080TI
    Graphic Driver Ver : 546.01
    Any help will be greatly appreciated.
    Thankyou
    Hi, thanks or posting.
    1 - Are you using V-Ray CPU or V-Ray GPU?
    2 - Do you have any errors in your log window?
    3 - Do you have any other messages popping up?
    4 - Is this issue happening with every scene or only in a specific scene?
    5 - Have you tried to reset your render settings to default and if you haven't please do (switch your render engine to scanline and back).
    Vladimir Krastev | chaos.com
      Hi, Thanks for reply.
      Am currently rendering the animation with VRay - CPU
      There are no errors in log window
      VRay just stops render after some frames.
      For Still Renders there is no issue. But for animations this happens for almost all scenes.
      Will try to reset default. but i dont think it will solve the issue because for each scene i use different lighting and rendering setup depending on the scene.
        A 3rd party plugin that may be causing issues. Check if you have something suspicious in your scenes.
        Do you have issues in a new simple scene?
        Have you tried to reinstall your V-Ray? Try deleting your leftover files as well.
