IPR Vray material using volume translucency CTD
  • IPR Vray material using volume translucency CTD
    CTD every time settings are changed....if not almost immediately then after a few changes.
    Noticed on one scene but tested on several others, all very basic, e.g. a sphere or whatever, camera, sun/sky.
    The attached scene should crash when you run IPR then make a change, which appears to any arbitrary parameter.
    Using Max 24, latest Vray.
    As others have been noticing, also seemingly crashing far more regularly on other full scenes of all types, so I'll try to note when that happens. Maybe it's unrelated to this thing.
    Hello,
    Can you share some more details on steps needed to crash ? I tried changing material settings, sphere params, camera, sun - no crash whatsoever.
    What are your exact Max and V-Ray version ?
    Can you share a crash dump ?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Hi Yavor...initially here's a movie showing what occurs https://www.dropbox.com/scl/fi/rza6m...eqxcwf5fs&dl=0
      I can never remember where the dump is saved...will look...got an address to send it to?
      It happens with SSS version too.
      Max 24 26.0.0.940
      Vray 6.10.08
        To add: I did think it may have been the dodgy slate editor but the compact is no different.
          I sent the .dmp to support
