I heard that you can only use it form the tool bar but for years my Vray toolbar is corrupt. ( I don't think that the way to solve this is to reconstruct my 3dsmax.ini file. sorry Chaos - ! You should find a way to solve it differently)
update 6.2 :Unified Light/Cmera lister is not there for my 3ds max 2021
If you don't want to follow what is advised, then just create your own toolbar with the buttons that you need, that still works.
Hi
Actually I did and it did not help. for a blimp it appeared and then gone. All I get is a long empty toolbar and the tooltips are like "$#@^" or similar. It has happened before.
Regarding creating my own toolbar - I tried but the command for the unified lister does not appear there. Watch this short video:
https://youtu.be/YDD84Dx57X4
Last edited by nirsul; 07-12-2023, 02:26 AM.3ds Max 2016/2021 (Vray 5.005), Windows 10 64bit , AMD 32/64 Cores, 128 gigs RAM , 2X GTX1070 8GB RAM
Originally posted by nirsul View PostI heard that you can only use it form the tool bar but for years my Vray toolbar is corrupt. ( I don't think that the way to solve this is to reconstruct my 3dsmax.ini file. sorry Chaos - ! You should find a way to solve it differently)
Is your V-Ray installed in an arbitrary location? If yes, you must do an additional step described at the bottom of this page.
My Vray is installed on my only workstation. I no longer use slaves. my 3ds max is on c:\3ds max 2021 when installing I do not modife anything.3ds Max 2016/2021 (Vray 5.005), Windows 10 64bit , AMD 32/64 Cores, 128 gigs RAM , 2X GTX1070 8GB RAM
