Texture Issues / 3ds max 7 + vray basic
  • Texture Issues / 3ds max 7 + vray basic
    Hi there. After posting this in the wrong forum a while back I've decided to move it over here as I'm still having troubles.
    William
    Hi
    I was wondering if someone could shed some light on a little problem I'm having with texturing and what happens to texture maps as soon as you try render out to a higher resolution?
    (click on the pics to get a better view) The above render was rendered at 1024x168, I was happy with the material and the lighting. However, when I wanted to render the same model at a 3000x2250 something happened. It seems that the uvw map, as well as the highlights, didn't get scaled up.If this makes sense.
    Is there a setting to prevent this from happening? Am I doing something wrong?My set-up is 3ds max 7 + vray basic.
    Thanks in advance.
    William
    EDIT: forgot to mention that Vray Basic is based on version 1.09.03n
    william, why dont you upgrade to a newer version of vray basic?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
