Render Node
  • Render Node
    This render node is madness! I can hit render, and my node will work, but then it will not. It is a crap shoot! I'll stop a render, make a tweak, and hit render again. Sometimes, the render node will join, but most of the time, it will not. I remember this same behavior when I had a render farm ten years ago, so it seems nothing has improved. Is there anything I can do? If not, I don't see a reason to pay for the extra node.
    [17:55:08.508] Warning : Could not connect to host 192.168.2.97:20204: No connection could be made because the target machine actively refused it.
    [17:55:08.509] Warning : Could not use any of the selected (1) hosts for distributed rendering!
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Today, I started and stopped a render three times. The second render began after 17 minutes (stopped contributing after two hours), but the first and third never started, and all three ran for at least 1/2 an hour.
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      I have a CAT 6 between the two machines, CAT 6 with a preferred IP and Wi-Fi with a preferred IP. I assume I should be using the ethernet IP; is this correct?
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Bobby you have a cat cable connecting the two machines? You need to run them through a switch, make sure switch is connected to a router. I would not use ip6, rather ip4, set the static ips for both of them so they are always defined.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          I don't have access to my router.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Okay, I ran some tests, and my render node only uses the WIFI IP, not my ethernet IP. I unplugged my ethernet cable and can still access each machine from the other, so my ethernet cable is doing nothing. I am not sure this solves my issue since I have been using my WIFI IP in V-Ray.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Multihoming with two or more IPs on a machine can be difficult to get right, and some software just may not support it. I would make sure everything is on a single, wired network. Both machines can be wired into your router. If you can't access the router then get a small switch (dirt cheap) and connect the machines to the switch, and then the switch to the router. You don't want to be simultaneously using WiFi and wired networks unless you have a deep understanding of networking.
                Nope, no access to the router. As long as the WIFI is doing the job, I am fine. It is surprisingly fast, but it makes sense that the extra node takes about 15 minutes to join. I didn't think you could render over WIFI.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  No access to a physical router? Or you can’t access the default gateway?
                  In either case your ip’s are probably floating all over the place.
                  you’ll also need to ensure the correct port is open which is specified in docs
                  Who is your internet service provider?
                    I assume he is sharing WiFi with someone else and the router is not in his area of control. ??
                      I rent an ADU, and the main house has a router.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Simply unplugging my CAT6 seems to have solved my issue. I tried both IPs, and both worked, but the CAT6 direct was flaky, and even if I removed that IP, it still caused problems. Unplugging it solved the flakiness.
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          Spoke too soon. Just as fast as it started working consistently, it stopped working consistently. I guess it is just the way to is!
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
