merge everything, including rendering layers
  • merge everything, including rendering layers
    Why when I merge an entire scene, checking everything including the rendering parameters, do I have to go and merge the rendering layers manually each time? If I select everything, I should have everything.​
    This is a Max thing I'm guessing.
    A.
    www.digitaltwins.be
      Hi, thanks for posting.
      Do you mean the render elements?
      On my 3ds Max 2024.2 everything merges as expected, including V-Ray settings and render elements:
      Vladimir Krastev | chaos.com
        Yes, I mean the render elements but Google translation translated those from french by Layers instead of elements. I am under 3dsmax 2021 and Vray 6. And it does not. I'll try with Max 2024. Thanks.
