lightmix doesn't refresh instantly
  • lightmix doesn't refresh instantly
    When rendering, Lightmix in the VFB doesn't refresh instantly (like in previous versions happened). For example, if i switch off a light source, i have to wait a bit of time to see effects on the image. Do you know why?
    Works fine on my end on a simple scene. Mind if you record a video illustrating the issue?
      Thanks for your patience, i was on a deadline.
      Here's a video with a fresh finshed render.
      https://drive.google.com/file/d/1Plp...usp=drive_link
      As you can see, in this case changing lightmix settings don't affect the final output at all.
      This happen in a similar way when rendering, where lightmix tuning is visible on output only with a certain delay (30/40 seconds on my machine).
        Interesting, can you save this render to a vrimg and send it to us ?
        Yavor Rubenov
        V-Ray for 3ds Max developer
          Thanks for the vrimg file. Here it seems to behave as expected and turning lights on/off is immediately visible. Is the problem reproducing for you if you restart Max and just load the vrimg file into the frame buffer without any rendering ?
          Yavor Rubenov
            Yeah, if I do that works fine for me too and it update any mod in real time.
