Sun Positioner and GPU Render
  • Sun Positioner and GPU Render
    is it normal that the Sun Positioner only works in CPU rendering and not in GPU rendering?
    Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.634 + V-Ray 7.00.03
    3DS Max 2025.3 + V-Ray 7.00.08
    3DS Max 2026 + V-Ray 7.00.08
    Chaos Vantage 2.8
    GeForce Studio Ready Driver Version 572.16​
    Hello,
    Sun positioner is currently not supported by Standalone and V-Ray GPU. In case you want to achieve correct sun position by date, time and location, you can use a Daylight system (3ds Max Menu Bar: Create - Lights - Daylight system). In the daylight parameters rollup VRaySun should be selected as a sunlight source. Thus VRaySky will be automatically set as an environment map.
    Philip
    Philip Shounev
    QA department
    Chaos
    philip.shounev@chaos.com
      Thank you. I'll give it a try.
      Chaos Vantage 2.8
