VRayCryptomatte problem
  • VRayCryptomatte problem
    My sample scene consists of 2 cubes (Box001 and Box002). The 2 cubes have the same material.
    I'm creating two Cryptomatte Rendering Elements :
    - one with ID Type = Node Material Name
    - one with ID Type = Node Name
    The 2 RE are named "VRayCryptomatte" (by default). This is important.
    I run the renderer and get 2 different RE. All is ok.
    Now the problem:
    In the VFB, I take the exposure for example, the 2 Cryptomatte RE are indeed present,
    BUT, whether I choose one or the other, only the last RE at the bottom of the list (1st image, the highlighted RE, in our case Node Name) is taken into account.
    The bug occurs if the 2 render Elements have the same name.
    If I name the 2 render Elements differently, then it works correctly.
    I hope I've made myself clear.
    Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 25.0.634 + V-Ray 7.00.03
    3DS Max 2025.3 + V-Ray 7.00.08
    3DS Max 2026 + V-Ray 7.00.08
    Chaos Vantage 2.8
    GeForce Studio Ready Driver Version 572.16​
    Hi, thanks for posting.
    Why is this necessary. I can't imagine a scenario where two different render elements with the same name is a good workflow.
    Vladimir Krastev | chaos.com
      Misinterpretation of what I wrote.
      I wrote that it was important because it was the fact that they had the same name that was causing the bug.
      Of course I don't need them to have the same name.​
      Chaos Vantage 2.8
        You can change the name of each of them and then distinguish what each one is - see attachment
          Please use proper naming to all elements of your scene. This is the correct workflow.
