V-Ray Camera's "Resolution override" aspect ratio changes even when it's locked
  • V-Ray Camera's "Resolution override" aspect ratio changes even when it's locked
    There's an issue with the V-Ray "Camera override" resolution feature. When I lock the aspect ratio, changing the "width" or "height" sometimes changes the aspect ratio even though it's locked. This happens on all workstations and it's been an issue since this feature was first implemented. Has anyone else noticed this problem? Would you like me to record a video?
    Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
    AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB (rendering) | GeForce GTX 1080 Ti FE 11GB (display) | GPU Driver 546.01 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2
    I have experienced this too, mostly when I have several vray cameras
    Carlos Rodriguez
    RTstudio
    Tutorials
      Some more information would certainly be helpful - video, setting values, scene. Thank you!
      There is mismatch between the aspect ratio in Camera override settings and the one in Render Settings with values that would not give whole numbers. I'll check what we could do about that. Could you tell me whether this is what your are experiencing or if it's something separate?
      Best Regards
      Maria Keskinova
      V-Ray for 3ds Max QA Specialist
      Chaos
        Hi maria.keskinova, as I can see, it happens when another camera has different IA and it chages to the previous one, once reseted, the IA its preserved, I attach a sample in max 21 with cameras and a Video showing the problem
        Carlos Rodriguez
        RTstudio
        Tutorials
          Thank you very much!
          I'm reproducing it and will look further into it. I've logged the issue - internal tracking number: VMAX-14091. Thank you for the report!
          Maria Keskinova
          Chaos
