Decal Displacement issue
  • Decal Displacement issue
    So i have a simple scene (attached) With a ground plane and decal. If i have displacement on both the ground and decal, using the material displacement attribute, everything seems to work. However if I use a vraydisplacement node on the ground object, the decal one no longer works.
ID:	1206059Click image for larger version
    e: info@adriandenne.com
    w: www.adriandenne.com
    Thanks for the report. It seems the VRayDecal's displacement settings (which are taken from the default displacement settings in the Render Setup) are overridden by the VRayDisplacementMod of the projected-on-object. There seem to be a few issues logged regarding the mixing of the two as well. Either way, these will be fixed when we eventually implement separate displacement settings for the VRayDecal itself.
      thanks bud.
