VRayBitmap vs Bitmap render speed
  • VRayBitmap vs Bitmap render speed
    My simple test scene consists of a plane on which I distribute a sphere with Chaos Scatter.
    Simple material with a "Bitmap" JPG file: rendering time = 3min16sec
    The same material with the same JPG file in "VRayBitmap": Rendering time = 3min31sec
    I've had fun doing other little tests and it happens all the time.
    Is it normal that the rendering time is longer with "VRayBitmap" than with "Bitmap"?
    Or have I missed something in the settings...
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 24.0.594 + V-Ray 6.20.06
    3DS Max 2024.2.3 + V-Ray 6.20.06
    3DS Max 2025.3 + V-Ray 7
    Chaos Vantage 2.6.1
    GeForce Studio Ready Driver Version 561.09​​
    If you are viewing it at an oblique angle then it could be the different MIP mapping used. The VrayBitmap will likely be a little sharper in the distance, and this would take more sampling, thus have a higher render time. But it would be sharper in a good way.
    Post your scene for more investigation.
      Hi, could you try a much longer render? A tree minutes render time and sixteen seconds difference could be a misleading result. Are you using CPU or GPU?
      Vladimir Krastev | chaos.com
        Hi, i've just redone a test with a slightly more complex scene.
        CPU Mode
        Bitmap = 5m49s
        VRayBitmap = 6m46s
        GPU Mode
        Bitmap = 3m59s
        VRayBitmap = 3m22s
        No visible quality difference in VFB compared to A/B.​
        PS: same render time with Vantage LiveLink between Bitmap and VRayBitmap
        Chaos Vantage 2.6.1
          I'm going to launch a 2k or 4k rendering of the same scene.
          Chaos Vantage 2.6.1
            Can you post your test scene?
              Impossible. This is a customer's scene.
              Chaos Vantage 2.6.1
                Can you reproduce it with a simple scene? Could be other factors in that scene, but those numbers are strange. I gotta say it's been a while since I time tested it, but last time I did they were the same or VRayBitmap was a tiny bit faster, and VRayBitmap most definitely does MIPmap differently, I posted a tone of tests a while back.
                You're doing anything silly like setting the blur to a low value, right?
                  As written in my first post, my first test is a simple scene with a default material and all the default rendering parameters. It couldn't be simpler.
                  Chaos Vantage 2.6.1
                    Could you run this scene with a lot higher resolution and render settings and share the result. Too short render times in the minutes range are not reliable for comparison.
                    If you are concerned about confidential scenes you could send them to the support contact form. The whole ticketing system and it's storage folders are well secured and the scenes are used only for troubleshooting purposes.
                      CPU Mode
                      Bitmap = 5m49s
                      VRayBitmap = 6m46s
                      GPU Mode
                      Bitmap = 3m59s
                      VRayBitmap = 3m22s
                      Same scene in 2K :
                      CPU Mode
                      Bitmap = 15m25s
                      VRayBitmap = 17m19s
                      No time for GPU testing​
                      Chaos Vantage 2.6.1
                        Here's another test with a simple scene rendered in 8K
                        CPU Mode
                        Bitmap = 37m15s
                        VRayBitmap = 39m1s
                        Chaos Vantage 2.6.1
                          As written in my first post, can you share the test scene
                          Oh, there it is now.
                            Thanks for the scene. I've ran a few quick tests. There is indeed some delay in render times with the VRayBitmap. We will investigate the issue further and get back to the thread.
                              I'm coming back to you to find out if the rendering time problem has been fixed or not?
                              Because I have another rendering time “problem”.
                              I did some tests with the file “Evermotion_Tutorial_01_Final.max” provided by Evermotion in their tutorial here : https://www.youtube.com/watch?v=QPjo...RaBWZw&index=2
                              It's an old file containing Skylight Portal.
                              Here's my 3DS MAX 2024 + VRay 6 workflow:
                              1st Test: Open the file, I don't touch anything except that I change Progressive Render to Bucket Render and run the render.
                              Render time in CPU = 4m46s
                              2nd Test: Open the file, remove the Skylight Portals, change Progressive Render to Bucket Render and render.
                              Render time in CPU = 6m15s
                              I ran the test with 3DS MAX 2025 + VRay 7 on CPU: identical results.
                              On the other hand, GPU rendering time is identical.
                              Where does this difference in rendering time come from?
                              Chaos Vantage 2.6.1
