vrscene "export selected only" exports unselected lights
  • vrscene "export selected only" exports unselected lights
    as title, unless the sun is physically deleted from the scene before doing an "export selected" using the vrscene exporter on a few objects, it gets included in the vrscene.
    Do you have an Aerial perspective?
      i do actually, but the problem occured way before i added it. it also occurs in maya, as the files i am sent sometimes have the same issue.
        It looks like the sun is attached to the environment via the VRaySky. If you just remove VRaySky from the background slot before exporting, it should not export the sun. At least this is what I observe.
