Reflections
  • #31
    Originally posted by Vizioen View Post
    Just a little test....
    The first image seems to be correct, except for the sky: the luminous sky reflection mostly makes everything inside almost invisible. Now it seems as if the sky is not luminous at all!
    Just a photo from Flickr:
    Click image for larger version  Name:	image.png Views:	0 Size:	1.61 MB ID:	1209028
    In reality the dynamic range ​of in- and outside lighting is far more than with the usual lighting setup with any HDRI or Daylight setup.
    To compensate for this I usually setup different output maps using the same VRaySky or HDRI to steer the environment, like Background, GI, Reflection and Refraction. Especially since clients often just want to see everything inside very clearly, which of course is unreallistic.
    • #32
      Originally posted by Joelaff View Post
      You have a Dome light ? Or are you using HDRI in the environment? Do you have the environment overrides on in the render settings?
      I use an HDRI in a skydome, and instance it in my environment, so I can see it in my viewport. I also have a V-Ray Sun, to boost my shadows.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
      • #33
        So you don't have anything in that highlighted override slot, then?
        Or also a Dome light that could be blocking the view of the environment?
        • #34
          specular multiplier in dome light then.
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
          • #35
            It's not very difficult to upload a stripped down scene but we can keep guessing ofcourse.
            A.
            www.digitaltwins.be
            • #36
              The problem is caused by Aliens? Or gnomes perhaps?
