Override material & render mask bug
  • Override material & render mask bug
    Rendering using a render mask will include the objects with override material applied even though they are not included in the render mask list.
    Regards
    Steve
    My Portfolio
    Hello,
    Seems to work fine here on a simple scene ? Can you share some more details or a sample scene?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      So, the reason I used a overidematerial was to control the shadow darkness. I had a vraycolor in the shadow slot. Not sure if this makes a difference to your test scene.
      If your test still proves to work as expected I can send you the scene. Can you remind me of the email address to send it to. Thanks.
      Regards
      Steve
      My Portfolio
        If it is a small/test scene - you can share it here directly. Otherwise you can submit it to our support (https://support.chaos.com/hc/en-us/requests/new).
        Yavor Rubenov
