something strange happens
  • something strange happens
    As you can see in the attached images, the more zoom the vray camera has, the more circles appear in the distribution of forest objects.
    I have contacted Itoo support and everything seems to be OK.
    any ideas?​
    www.oscarlorenzo.com
    You'll notice that the circular patttern's centre is always at the centre of the frame.
    My guess is that it's because it's a directly top down view, which can cause problems in other scenarios as I recall.
    So some rotation of the view will greatly eliminate the issue.
    Someone else here can probably state exactly why it happens but that may be a solution meanwhile
      This happens because the scene is too far from the origin (your camera is floating 8km in the air), which can lead to raycast errors. Divide the camera Z coordinate and Focal Length by 10 and you'll notice good results.
        thanks for the answers, I'll keep that in mind
          Using 200mm the circle is very appreciated, the curious thing is that it only passes through the forest objects...
          Ideas ???
