V-ray lens effects missing for 3ds max .exr output + alpha?
  • V-ray lens effects missing for 3ds max .exr output + alpha?
    Hellooo,
    I'm having trouble with V-Ray lens effects since updating to V-Ray 6 Update 2.1. Previously, when enabling lens effects in the VFB, they would render directly onto the .exr output beauty renders. Now, however, the lens effects are rendering as separate effects passes and are not embedded in the image.
    I primarily use After Effects for compositing, not Nuke. When I import the .exr sequence into After Effects and apply the lens effects pass using the SCREEN blending mode, it doesn't replicate the same quality of effects I initially tweaked in VFB in 3ds Max.
    Could someone please guide me on how to embed lens effects directly into the .exr export beauty shots? If this isn't possible, is there a different blending mode in After Effects that would better replicate the same effect? What is the recommended workflow for this scenario?
    Additionally, when it comes to VFX compositing with an alpha channel, rendering lens effects on an alpha background causes issues with edge cuts. How should I address this?
    Thank you!
    PC Specs: CPU i9-14900K - GPU RTX 4090 - RAM 192GB 5200MHz - MB Asus ROG Maximus Dark Hero
    Hi, please check if you have enabled the "Create effectsResult channel". Also for compositing, use the glare channel.
ID:	1210387 Click image for larger version
    Vladimir Krastev | chaos.com
      by default it is on! didn't touch the settings in VFB
        by default it is on
        Please make sure it is indeed on before you start rendering.
        What do you mean by beauty renders? We have a effects result channel that contains the RGB + lens effects applied.
