.jpg and VFB difference
  • .jpg and VFB difference
    Hello community,
    I'm having a strange issue when saving images as a .jpg compared with what is shown on the VFB. I've attached examples of the jpg and screenshot of the VFB. Would anyone have any ideas on the cause? Thanks.
    Could it be that Color Management in 3ds max is set to OCIO?
    How is configured your VFB in Display Correction?
    Carlos Rodriguez
    RTstudio
    Tutorials
      Both settings are on sRGB?
        for 3ds Max Color Management I meant this one, in recent versions is automatically set to OCIO
        Carlos Rodriguez
        RTstudio
        Tutorials
          Hi. I just checked and can confirm my settings are showing the same as your screenshot.
            Damn I was hoping that it could be that, how about the Gamma when saving the image? is it in 1.0 or 2.2?
            Carlos Rodriguez
            RTstudio
            Tutorials
              Click image for larger version  Name:	image.png Views:	0 Size:	8.4 KB ID:	1213156
              I always set the Gamma to Override 2.2 manually on every save.
              It's a pain, but it's the only way I've found to get the right color.​
              Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
              Sketchup PRO 25.0.571 + V-Ray 7.00.03
              3DS Max 2024.2.7 + V-Ray 6.20.06
              3DS Max 2025.3 + V-Ray 7.00.04
              Chaos Vantage 2.7.1
              GeForce Studio Ready Driver Version 572.16​
                Originally posted by DCHA34 View Post
                I always set the Gamma to Override 2.2 manually on every save. It's a pain, but it's the only way I've found to get the right color.​
                If the 3ds Max native's color corrections are set to Gamma Workflow and Gamma 2.2, this should happen automatically (Automatic option). If it still happens, attach a sample scene so we can troubleshoot.
                  I'm in Gamma Workflow and Gamma 2.2 and the automatic mode has never worked for me.
                  TestGamma22.rar
                  Chaos Vantage 2.7.1
                    Thanks for the provided scene. Something was deeply messed up with the color management settings in your particular scene. The issue occurred in Scanline as well.
                    Found a quick fix, however. Go to the Color Management settings, click "Load System Defaults" and afterward switch back to Gamma Workflow.
                      It doesn't work. Still the same problem.
                      Chaos Vantage 2.7.1
                        My problem has been resolved by manually adjusting the Gamma override figure to 2.2 recommended by ChuckRT​. Thanks! ​
                          Another way is to merge the scene into a fresh one, where Gamma Workflow is set. This worked for me. Also, a good idea is to check your environment variables.
                            Hi Aleksandar,
                            what checks should be made on environment variables?
                            Chaos Vantage 2.7.1
                              Hi Aleksandar,
                              Ignore. I assumed 3ds Max had an environment variable for setting the default color management, but I can't find such.
